Earth's in a ring
Benj2012
Mar 2, 2016
7
When terminating the two earth Conductors for a ring would you put it in the same terminal or two separate ones
Didn't mean it in a rude way just got exam tomorrow and needed an answer, sorry  :Salute
so you expect to be spoon fed all the answers to pass your test but have no idea where to find the answers yourself?
in some cases it can make a difference, and the answer is in 7671
@Benj2012 a ring circuit is considered a single circuit. The two brown (line) cables are connected together, the two blue (neutral) cables are connected together. It therefore follows that the two earths are connected together.
Just got confused cause it says in on site guide separate terminals
I have looked but my teacher has told us the cpc goes in the same terminal but 7671 says different terminals
Think about it this way....
What difference would it make if they were under two, separate but linked,  terminations as opposed to 1?
and.... are there any regulations that might state that they should be under separate terminations?
Just says in on site guide only reason that I could think it matters is putting out of place the earthing arrangement of the mcbs
