Hi guys i have been asked to price a job to replace lights in the eaves of a house 10 GU10 type in total.Do they need to be firerated or would the basic type do?
thanks
Eaves lights???
as in OUTSIDE overhangy bit where roof and wall sort of meet?
Firerated....
This is not meant to mean that the light itself will not set fire to its fixing structure...
Fire rated fittings have expansion strips that swell and block apertures preventing the passage of smoke from one room to another in the event of a fire..
Primarily to reduce the passage of smoke into inhabitable rooms above a room where a fires starts...
e.g.
Garage doors require the heat strips and self closers, to stop fire getting through the doorway in the event of a garage fire ...
Fire rated lights in one room reduce the passage of fire between the ceiling void to the room above...
Now forgive my thickness but fire rated in this instance would be theoretically reducing the passage of smoke from outside through the eaves into the roof void?
No inhabitable room above...
and its OUTSIDE anyway...
smoke will not be contained in an enclosed space trying to get to upstairs room...
It would potentially be already outside and just blow across the garden!!
I would think just Damp and weatherproofness is more important.
