Hi
Have just joined and tried to follow the info to edit my profile to let people know a bit about me. Unfortunately say I am not allowed to edit my profile, seems a bit strange but as it is.
I am not one of these people who join a forum get answers to a question then disappear off into the ether. Will admit probably not be on here like some folks are on certain forums, but each to their own.
Anyway I decided to join as I need a s[ecific bit of info. One of my daughters decided to do away with her economy 7 arrangement, against my advice. When she moved in she had storage heaters which have since been removed.
Before the meter change I disconnected the wiring from the night time CU and put it into the normal rate CU, plenty of spare ways, so now she has 3 more sockets dotted around the place. This now left only the HW night time rate wiring in
the 2nd CU. As it turns out after getting the meter changed her hot water does not work, can only get any by using the boost switch. Now to my mind it looks as if the nightime setup has been discarded.
. What I notice is that there are 2 neutrals disappearing off into the flat but only one live. Should there then in this case not be 2 lives? Cannot see anywhere to add an attachment and the link thingy does not seem to work so here is the link tot he meter setup.
https://ibb.co/1vS35J3
Hope this made sense.
