Eicr Recommendations.
gselectrical
Oct 13, 2009
627
Afternoon all.
Would value your opinions on the following.
We carried out an EICR on a new property wired 3 years ago.
Various problems identified such as labelling & missing blanks etc.
I also noticed there is no heat detector within the kitchen. There are 2 detectors one in the hall and one on the landing. Should there not be a heat in the kitchen to satisfy building regs?
Also there is no extractor fan within the ground floor toilet, again as far as I am aware, there should be one to meet building regs?
As these are not electrical faults as such should I be mentioning them in the report?
GS
A room with just a toilet, does not need an extractor unless it does not have an opening window.
It's only rooms with a bath or shower than need an extractor (and kitchens and utility rooms as well)
One smoke per floor is often enough. It must have passed building control when it was built so it's okay.
So all that's wrong is missing blanks and labels. IMO it's just as quick to fit them while you are there, rather than leaving them and "failing" it.
Thanks guys,
I fitted blanks & labels before I left. As you say, it would probably have taken me longer to input the deviations rather than just fit the blanks & labels.
"New build (up to three storey)
Grade D, Catergory LD2
Smoke detectors should be installed in circulation spaces, heat detectors in kitchen and principal living room (smoke detectors are an acceptable alternative in living rooms)"
Which is why I thaught a heat detector should have originally been installed, but as you say if it has passed building control's inspections, then it must be acceptable in thir eyes.
Cheers
GS
I was told on my last assesment. You should mention these things on your observation page but do not add a code.
