Stulee
Can you hard wire a 13amp cooker lead into the mains.
I have a cooker outlet socket from the old cooker. My new oven has a 13amp fused plug so it would be ok to cut it and connect it directly to the mains?if the connection point is suitable then yes
Ok thanks. Yes it all ready has one of those switches. I will just change the front plate to a plug switch plate. The cables are thicker than standard socket cables. Would this be ok?You could just replace the what I assume to be an outlet plate for a socket outlet but it would require additional rcd protection if not already in place.
youll probably need to change the rating of the circuit, change the outlet for a fused spur or a socketI have a cooker outlet socket from the old cooker. My new oven has a 13amp fused plug so it would be ok to cut it and connect it directly to the mains?
