depends on your version of 'local'This crops up a lot. All fixed appliances must have a local isolator. Put it in the corner furthest from the shower or a 45a DP switch on the wall outside bathroom. My mate insists that the pull cord is within reach of the person in the shower, if you can find that in the regs you're a better man than I ,Gunga Din.Deke
well if its a Crabtree switch.. manufactures instructions say.. and I quote;This crops up a lot. All fixed appliances must have a local isolator. Put it in the corner furthest from the shower or a 45a DP switch on the wall outside bathroom. My mate insists that the pull cord is within reach of the person in the shower, if you can find that in the regs you're a better man than I ,Gunga Din.Deke
And as regs 134.1.1 says amongst other things that manufactures instructions should be followed..Notes:6. When used in bathrooms, pull switches should be fixed out of reach of the bath or shower.
depends on how crabtree mean out of reach.... does this mean the cord is out of reach, or the switch is out of reachwell if its a Crabtree switch.. manufactures instructions say.. and I quote;And as regs 134.1.1 says amongst other things that manufactures instructions should be followed..
then your mate would be wrong in this case!? :|
