Electrical Circuit & Personnel Protection
elechelp
Jul 27, 2014
3
Newcastle
Hi everyone,
I'm having to put together a list of components to protect circuits and personnel in
-domestic premises
-commercial premises
-light industrial buildings   (from this I will then have to provide technical info which I will research)
So far I have the following list
RCD PLUG IN RCD ADAPTOR PLUG IN NON-LATCHING IN-LINE RCD SOCKET OUTLET (WHITE/METAL) RCD PROTECTED FUSED CONNECTION UNIT FUSED CONNECTION UNIT INTERLOCKED SWIRCHED RCD SOCKETS RCD SOCKETS FUSES – PLUG TOP BS88 FUSES MCB TYPE B MCB TYPE C MCB TYPE D RCCB RCBO RCD – DP RCD -TIME DELAYED MAIN SWITCH?? SURGE PROTECTION KIT PORTABLE TRANSFORMERS?? MCCB SP&N BOARD MAIN/SPLIT/HIGH INTEGRITY TP&N BOARD GARAGE CONSUMER UNIT FILTER SOCKET ANTI SURGE EXTENSION LEADS SHOWER CONSUMER UNIT MPCB (MOTOR PROTECTION CIRCUIT BREAKER) PV CONSUMER UNIT BONDING CONDUCTORS
Just wondering if anyone else has any suggestions, anything that I have missed.
Your help would be much appreciated guys.
RCD Plug in,
RCD Adaptor Plug in,
Non-Latching in-line RCD,
Socket outlet (Plastic/Metal),
RCD Protected Fused Connection Unit,
Interlocked Switched RCD Unit,
RCD Sockets
Fuses - Plug Top,
BS88 Fuses,
MCB Type B,
MCB Type C,
MCB Type D,
RCCB,
RCBO,
RCD DP,
RCD - Time Delayed,
S Type RCD,
Main Switch,
Surge Protector,
Portable Transformers?,
MCCB,
SP&N Board Main/Split/High Integrity,
TP&N Board,
Garage Consumer Unit,
Filter Socket,
Anti surge extension lead,
Shower Consumer unit,
MPCB (motor protection circuit breaker),
PV Consumer Unit,
Bonding Conductors,
Hopefully this will post better, sorry I just copied my spreadsheet. It is part of a project for college to increase my knowledge. There is also technical info to include but i'm OK with that just the making sure I've covered as much as I can!
Thanks for all your answers
Isolating transformers in shaver sockets?
Low voltage (12V) equipment in some bathroom zones? (SELV?)
Local isolation - shower/cooker?
Appropriate IP ratings?
Would just MCB not be sufficient. You have started to list types of MCB.
Could you just say OCPD
just electrical devices on this. I have had to put the MCB's separately as I have to put the breaking capacities of each item
