Electrician & Mates Required Burnley / Blackburn / Liverpool / Leeds / Barnsley Immediate Start
select elec
May 1, 2009
18
We have projects running in the following areas Burnley / Blackburn / Liverpool / leeds / Barnsley and require electricians and electricians mates you must have CSCS card / JIB cards are preferred for more details call 07789202060, Thanks
We still require electricians and mates for the blackburn and burnley areas
Unfortunately with very little info most will not apply. If you could provide any further info you may get a better response.
We are still looking for electricians and mates for a project starting on the 12/8/13 in blackburn it is part refurbishment on a school
Does JIB cards preferred = JIB rates?
Anyone interested is advised to call the number in the first post, we do not feel it is appropriate to discuss rates over the forum, as not every body has the same level of competence or experience. this is in no way ment to sound disrespectful.
Thanks for looking
Surely the JIB card is supposed to ensure that people holding it are suitably competent?
BTW, I'm too far away & too expensive for you! ;)  Trust me...
Snowed, snowed!
I've got a factory move, en masse, to look at Monday, the whole bloody lot, goodness knows how I am going to pull that off with everything else I have on!
Around 100 machines, plus all "support" and circa 1000 sq m is all I have been told at the moment.
Within reason its mine, don't know where to turn TBH!
We still require 2x sparks & 2x mates for a project in the Barnsley area it is mainly wiring & terminating SWA cables, cable containment & mounting pre terminated panels
Snowed, snowed!
Sounds to me like your the one who needs to employ a bit of labour .
Nope, been there done that been stitched up.
The only way I would employ now is subbies or on zero hours contracts which are hot news at the moment.
Plus getting competent people is impossible for the rates that clients will pay.
We still require an electrician in Liverpool it will mainly be installing dado trunking and light fittings
