Electricians tools
Never belived in them and have never used on or tried to use on never will,
Hence i gave mine to good home by the name of Steptoe.
So what happens if you want to test if something is live (like a light switch) but there's no neutral or earth to put the other probe on?
Do you take a long wander lead off to the nearest neutral?
Could use a variety of methods but none of them would be the use of a neon screwdriver
Also some flukes have an audiable alarm when one probe touches a live conductor, but usually I put it on the earth that should be in the backbox, if its not there I'll look for the nearest earth.
Hang on a minute.... If you have no earth or neutral, how would u test with a neon screwdriver ? You need to be a reasonable earth for the neon to light, so if your stood on a wooden floor or wear rubber boots prodave has the same problem as someone with a set of multitesters.
I will admit I use non contact fluke pen as a secondary check, and it has saved me a shock once or twice over the years, maybe put one of them in your screwdriver set !
Just one example will do.
My tongue
A neon screwdriver only requires a TINY current to flow. So just touching a wall for instance will give a high impedance path to earth and will be good enough for the tiny current needed to light the neon.
I disagree, a wall is not going to give u enough potential difference to light a neon, if it did then I could shove my testers on the same wall and get a reading of the voltage. I'm not 100% sure but don't you need a difference of 90v to light a neon ?
I disagree, a neon needs such little current it will light.
Even after all the years i have been doing this is i still wonder how you can get a shock, when your standing on wooden steps, wearing rubber trainers, on a nylon carpet, with rubber underlay, on wooden floorboards, in a brick built house, on the 3rd floor ?
I use a kewtech kewstick as a secondary. Also great for where you have no exposed parts. Found a faulty mcb with it last week just by tracing over the board till the light went off.
Cant remember the last time I wanted to test something and had no earth or neutral within reach!
Even if you're at a remote class II device with just a live supply and a switched live out & no earth, if you're using a digital tester with high input impedance you could use the switch live wire as a neutral for test purposes as the resistance through the load it's supplying is immaterial compared to the tester input resistance. Otherwise a trailing lead from a known neutral/earth is better.
Neon screwdrivers needing very little current to light is also a problem, they will sometimes indicate a wire is live when there's nothing but a capacitively induced surface voltage, the kind of voltage that confuses apprentices when they see a 90 something volt reading on a digital meter that's testing a wire that's disconnected at both ends and can't understand why they get a 0 volt reading on the same wire with an analogue tester..
lets say you are in a loft and there is a buch of cables all taped together running the length of the loft before disappearing into a small void, and then you spy a solitary bare end of a single red sticking out, how do you test it?
