L Lee321 Distinguished Member Joined Sep 8, 2008 Messages 2,141 Reaction score 0 Mar 5, 2010 #1 i need a diode to carry 20amps. how? possibly it becomes called something else at this current level? 12v dc btw ray
septiclecky Distinguished Member Joined Oct 17, 2008 Messages 1,843 Reaction score 7 Location Wirral Mar 5, 2010 #2 i need a diode to carry 20amps. how?possibly it becomes called something else at this current level? 12v dc btw ray Click to expand... It comes under the heading off a power diode you can get them for very large dc rectifiers
Andy™ ©Resident Geordie™ Supporting Member Joined Jan 1, 2009 Messages 30,747 Reaction score 1,471 Location S. Tyneside Mar 5, 2010 #3 1N5401 are rated to 3A, so you could bunch 7 of these together or you could do as suggested above and get a 20A rectifier
ProDave Twatt ™ Supporting Member Joined Nov 28, 2009 Messages 14,839 Reaction score 1,020 Mar 5, 2010 #4 Don't rely on putting several diodes in parallel. Each will have a very slightly different forward volt drop so they won't share the current equally. You want something like this http://www.maplin.co.uk/Module.aspx?moduleno=46429 rated at 30A, it will need to be mounted on a heat skink.
mikep Gold Member Supporting Member Joined Mar 15, 2009 Messages 444 Reaction score 0 Mar 5, 2010 #5 Might be worth fitting a stud diode with heat sink RS will have these ??
P PBC_1966 Senior Member Joined Dec 22, 2009 Messages 311 Reaction score 0 Mar 7, 2010 #6 If this is for a power supply of some sort where you are using a C.T. transformer and full-wave rectification, you can get a dual diode combined into a single package for easy mounting on a heatsink. For example: http://www.rapidonline.com/sku/Electronic-Components/Discrete-Semiconductors/Rectifier-Diodes/High-power-dual-Schottky-rectifiers/76074/47-3650
