Good evening all. I hope someone can shed some light on this issue. Today I replaced 3 mechanical time lag switches with Danlers WACE PIR 3 wire occupancy switch to control 4 maintained emergency lights in a stairwell.
All wiring is good and and sensors work well to activate lights but after the switches have timed out the first 3 lights come on in emergency mode. After a few seconds the first light switches off but next 2 remain on in emergency mode and the last light is not affected.
Supply is PME and the circuit is protected by an RCBO.
I’m thinking there must be some residual voltage confusing the emergency pack. Any thoughts would be appreciated, I’ve read many threads on this forum when in a pickle and learnt a lot.
Thanks in advance
Thanks in advance
