Been years since i did this sort of thing, still cant believe i know nothing and I done a excell project as a part of a higher GNVQ!
Anyway, not even sure if this is possible.
I want a cell to look at another cells result then compare it to see if its between two figures if it is gives a result. for example:
Cell result = 4
Next cell looks at it and sees if its between 0-5.99 it is, so the result is 6.
next block of numbers would be 6-9.99 result would be 10.
I think you will be able to see where this is going all the way up to 63. is that possible?
Cell result = 4
