Sparkyadrian
Will I require to change the rcd sockets to standard if I fit rcbo's to the db?
No Dave,
The instructions to disconnect are because they are electronic devices in the main and could be "fried" by 500V to earth!
In the experience I have of fitting dozens of these in a redundant role as I explained above, testing @ the "new" upstream RCD & the downstream RCD s.o. the RCD s.o. has no affect on the disconnection time in reality.-
Remembering that an RCD should be tested with all downstream loads disconnected, and a cable is seen as a load by an RCD...
Stupid that an RCD can pass test under BS7671 but still fail to disconnect in the event of a fault when in circuit, and this is OK, unlikely but OK!
Love it! Sorry - I edited the post as I engaged my brain!! Friday night is whisky night - I won't do it again!Canoeboy said:Stop talking about Steps that way :slap
:coatCanoeboy said:You on the Whiskey and Steps hasnt been invited ? msl:
thats NOT whiskeyCanoeboy said:Drink a mans Whiskey then
http://www.oldpulteney.com/old-pulteney-whisky/old-pulteney-40-year-old/
(Im not a whiskey drinker but got this for a customer and apparently its ok)
what ones?Thanks for all the replys really appreciate them. Thanks again
