Extending Cables inside CU
m4tty
Scaredy cat™
Feb 5, 2009
5,612
If you need to extend the cables inside the CU whilst doing a change and you need to extend 6mm or 10mm cable what would you use.
Yellow crimps wont be big enough so what would you do here?
Thanks:put the kettle on
yellow will be for 6mm but as said uninsulated 10mm crimps then insulate ;)
