Robojin
- Jan 22, 2009
- 1,122
- 0
Well had a chance to look at this in daylight, perhaps not pyro after all?
Outer sleeve white PVC?, solid copper sleeve (currently used for CPC) inner 2 core both black and appear to 1.5mm copper single strand
CPC is connected to metal surface mount switch box via large cooper glands
Not touched the cooper glands to see if inner cores are separated with mineral, is this pyro? I'd just assumed it was due to copper sleeve
Special on your question on the IR test, with my KT64 I get >200M between Line conductor and Line return, and CPC for the two circuits terminating at the wall switch (simplest way of bypassing timer switch), the actual IR numbers differ on each circuit I'm assuming this is down to the differing lengths on the run to the coach lights
