Robojin
- Jan 22, 2009
- 1,122
- 0
Need to replace a 20+ year old existing pair of external front coach lights, seems the lamps last a few weeks then blow, currently wired in mineral, and add a luminaire under the outside front porch
Looked through the big red book, nice index back and forth, round in circles X(
As my local supplier does not seem to carry mineral, am I off the mark using HiTuf back to 6A (RCD protected), the cable would be surface clipped at 7'+ for most of the run, I've yet to calculate volt drop and Zs for the length but likely less than 25m
Also installation has a 24hr timer, the regs seem a little ambiguous on this point, it would switch of, but unless I utilise IR too of course, the lights would still be on "people not detected" when dark, how do you interperate this
