Extracting the....
NozSpark
Seaman stains™
May 28, 2008
12,329
141
North Wales Riviera
.....damp smelly air from a shower room..
Got a job to do and customer is fitting a false ceiling below a vaulted roof (with roof lights). As the shower room is totally internal they are putting some glazing in the ceiling for natural light (this doesn't affect my work) and it will require extraction above the shower cubicle.
I was thinking of a SELV extractor fan in the ceiling (above will be inaccesible after work) with a duct upto and then through the roof light which they will get altered to suit..
and now to my question,, is there a window kit available for this situation? bearing in mind that the roof light is at approx 45deg so it will need to have a cowl.
Last time I needed to vent a shower extractor through a roof, I got the customer to first get a roofer in to fit a vented ridge tile to connect the shower fan to.
Normally that's what I'd do, but I'd rather not disturb this rather old roof..
Only real problem is that there are in fact 2 shower rooms (back to back) under the same vaulted roof / false ceiling... so there are 2 extractors in reality requiring 2 vents (or I suppose I could use a Y connector and butterfly backdraft shutters)
That's why I'm asking you good folk to see if anyone else has had this problem before and found a solution to it..BTW the fan cannot go in the roof space or in the window it's self
Sorry not something I have done.
Won't the rain come through?
possibly. i have fitted a fan into a window a few weeks ago, but it was not on an angle/roof. but id imagine there is something available? maybe an outlet with a cover, similar to how the roof vent would be?
