Theorysparky
Domestic Electrician
- Feb 18, 2008
- 4,232
- 0
Then they shouldnt be doing the job !!!!! headbangPlease say three core and earth we don't want some plumber or diyer doing it with three core flex.
The Reg is clear G/Y can ONLY be used for CPC.The reg 514.4.2 (pg91 BRB) can appear confusing.On reading it is quite explicit in that
bi-colour (yellow/Green) sleeving can only be used to indicate CPC
Single core (yellow/Green) can ONLY be used as CPC
This leaves the unsheathed wire in T&E, 3C+E which by impplication, or the regs would explicitly ban it, to be used as required, as long as it is sheathed at termination at both ends.
The problem herein is where someone cuts into a cable to say create some kind of spur and unaware uses the bare conductor as an earth !!!!!.
Maybe this is something to consider, now and for 18th Edition- haha
I agree with your sentiments SparkyTimThe Reg is clear G/Y can ONLY be used for CPC.IF INSULATED Single core then MUST be G/Y ALL WAY
IF BARE must be SLEEVED EITHER ALL WAY or at accessible positions
No one knowing what they are doing would NOT expect uninsulated conductor within a Cable to be the CPC.
3 Core and earth cable only has 3 INSULATED conductors, the outer cover is a SHEATH not counted as BASIC INSULATION.I agree with your sentiments SparkyTimHowever
Point 1. Fully Agree
Point2. Fully agree
Point 3. If bare AND used as CPC must be sleeved/taped
However nowhere does it say the bare (Specifically T&E, 3C+E here) has to used exclusively as a CPC only that if it is, it must be coloured correctly.
I am only playing devils advocate with the actual wording - I would not use the bare conductor for anything else either.
If anyone can find anything else on this it would be of interest:coffee
Steve,I agree with your sentiments SparkyTimHowever
Point2. Fully agree
