Robbo
- Oct 12, 2008
- 105
- 0
Whats the opinion on installing these?
I shall give you the scenario.
Bathroom 4" fan with pullcord. Situated in bathroom. Fed from bathroom light. Lighting circuit is RCD protected.
Can the fan be fed straight from the light? Or do I need to loop outside the room to a isolator switch and then back to the fan?
In the past I have installed these fan switches but they are traditionally installed above bathroom doors, out of reach. And customers often look confused as to why they are there.
Is there a reg that states they are required? I can understand the need for a switched fused spur if say a kitchen fan is part of the ring to enable the fan to be correctly fused. But on a lighting circuit?
Isnt it something to do with maintenance? Being able to work on the fan safely without shutting off all the circuit. But is there a regulation stating this?
Many thanks.
Many thanks.
