Hey all, did my am2 last week....
was so nervous, as i live on my nerves! couldnt even eat my breakfast on the days i went.
Passed my job, and testing, but i struggled and failed on the fault finding.
I work in the domestic enviroment, and managed to find the faults on my ring main, co2 circ, data.
Have any of yous had these faults? incase i get them again, so you's might be able to point me in the right direction, of where i went wrong perhaps?
I got two faults on my motor and 2 faults on my heating, which i could not find.
Fault - Motor: Motor will Not operate
So, I thought i might have an open circuit on the Line's, or Neutrals.
belled each on out, couldnt find a thing. Only thing i could not get a ring on was the incoming/outgoing neutral terminal in the DOL starter.
The supply line buzzed out, but when i went to the bottom it didnt, but i dont no if its supposed to with it not being energised?
Fault - Motor: Tenant complains on a tingling feeling when touching the dol starter and water pipe
belled everything out, but never used IR tester, possibly N-E you supply to dol starter inside the steel trunking you think?
Heating Faults
When calling for hot water the MCB trips
Boiler and pump continously running
both possibly shorts but could suss out where to test between.
Heating Faults
