thinker
Active member
I have been trying to get my 3 way down stair hall switching to work, I have eventually narrowed the problem down to a non viable common between the intermediate switch and the end of line switch, is it possible to use the earth suitably sheathed to replace this duff common?
Box 1, single two way switch near lounge door.
FFB Live +yellow from 6243y in 1 way portal
Live from light + blue from 6243Y in 2way portal
FFB Negative and light negative in electrical connector
Live from 6243y to common.
all earths to back of box.
Box 2 intermediate. Bottom of stairs. single two way switch (adjacent to 3 way box 3 1st floor landing light .)
Both reds (Commons) connected via electrical connector . ( The red to switch three appears duff.)
yellow from box 1 into top portal 2 bottom portal 2 has yellow to switch 3
Blue from box 1 into top portal 1. Bottom portal 1 has blue to switch 3
earth to back of box
Box 3 top of stairs one half of 2 gang 2 way switch ( the second gang is the ffb for the 1st floor landing 3 way)
Yellow from box 2 (intermediate) into portal 1.
Blue from box 2 (intermediate) into portal 2
Red into common (Duff)
earth to back of box with others from other gang.
What do you think?
What do you think?
