File Transfer
extension15
Distinguished Member
Feb 13, 2008
1,658
Greetings..
As the title implies, my PC (XP SP3) for some unknown reason, appears to be rather slow when transferring files from anywhere almost..
(Even from one folder to another on the same drive!!)
Sometimes it can be quite expedient in the exercise, others it stalls and the hard drive rattles away..
My PC advanced settings I believe are correct...
Any ideas would be welcome (Registry has been cleaned/Defrag etc)
What RAM and Hard drive amounts do you have Kevin?AndyGuiness Drink
It's a Dell Dimension 3100..
1G of RAM..
Bags of room on the Hard Drive (I store data in external HD's)
There is a network running to the Broadband box.
I have 100GB of free space on C drive..
I've tweaked as many things as I can...
I'm just wondering whether it is time to wipe the Hard Drive (completely reinstall)?
:eek:
(Hope not)
There is nothing wrong with the amount of space on your hard drive Kevin. Your RAM is the one you should worry about, it is this memory that your PC runs short term programs, file transfers etc. If you dont have enough, then everything runs slowly.
AndyGuiness Drink
There is nothing wrong with the amount of space on your hard drive Kevin. Your RAM is the one you should worry about, it is this memory that your PC runs short term programs, file transfers etc. If you dont have enough, then everything runs slowly.AndyGuiness Drink
Andy:
Are you saying that where the files to be transferred exceed the size of the available RAM, it will have to clear this when full (hence the stalling every so often?)?
But what about virtual RAM?
:| :D
Andy, while I've been here:
I've just done a 680MB file transfer, it was instant....
the same transfer earlier took 25 seconds...........
:eek: :O
Is your anti-virus software scanning or updating at the time you are trying to transfer files?
What's the mischief smiley face for EXT? :|
You realised why it is now slow at certain times, Yes?
What's the mischief smiley face for EXT? :| You realised why it is now slow at certain times, Yes?
Incorrect smiley...
My AVG is automatic and or prompted by me....
Perhaps I should turn off a few things and see if speed improves..
Pray
Also if you have the "Automatic updates set ON"
will slow things down whenever the PC decides to go a looking for updates to your Windows or uncle virus.
Setting them to manual update so they only go when you tell them will easy a bit of processor time.
Also if you have the "Automatic updates set ON"will slow things down whenever the PC decides to go a looking for updates to your Windows or uncle virus.
Actually AVG gives itself a time, rather than constantly requesting an update..
Perhaps after so much activity on the PC, it is time to wipe and or replace the HD..
:_|
Actually AVG gives itself a time, rather than constantly requesting an update..Perhaps after so much activity on the PC, it is time to wipe and or replace the HD..
:_|
Or do you need to give that big key a turn on the back.....
keep the clock-work wound up? ; \
I know admins is a clock work PC.... :p
every so often it stops and looses a bunch of posts! ]:)
Andy:Are you saying that where the files to be transferred exceed the size of the available RAM, it will have to clear this when full (hence the stalling every so often?)?
:| :D
OK things to consider
First lets cover RAM, XP with 1GB should be fine, although I like many have 2GB, the main use of RAM for the first 500MB is to load XP off the hard drive, cause RAM is obviously not limited by mechanical speeds (just the clock rate of the CPU)
Why have more than 512MB, it reduces/stops virtual disc swapping when running multiple applications, for instance email, browser, Word chew up memory, clearly if apps take an age to open it's down to XP taking a memory snap shot and swaping out to a reserved section on the hard disc to load you next app into RAM, I'd not expect transferring files speed to be down to this issue even if you were up in the 950MB RAM usage, unless you were moving very large files of 100MB's+ in size, due the the file buffer design within XP
Areas to look
Firstly did this problem start in the last few days?, if yes, have you installed any apps that are taking excessive CPU clock cycles (e.g. at the cost of the File System), every app gets a share of CPU clock time some get more priority than others dependant on this prioritisation, you can check this in Taskmanger, in typical system System Idle Process would be the highest at 99% even with office type apps running (only games tend to tax modern PC's), if you see svchost.exe running at high number this could possibly suggest the presence of a trojan or virus, or you may see a badly written app hogging CPU cycles effecting your file transfers
Where are you transferring from/to? if you have one physical disc split in to multiple partitions you are still using the same read/write heads, small files can be managed by the drive buffers, and larger by the File System buffering (NTFS is more efficient than FAT32), so moving very large files would drag performance down extra memory may not yield much benefit as the bottleneck is the drive, the cure is a second hard drive, the bottleneck moves elsewhere but might not be noticeable
You may have a 100GB of free space reported, but is it contiguous?, Windows is not particularly good at disc space management, so periodically running a defrag app can improve performance on drives as it reorders disc space into contiguous files that will load a lot faster thereafter
Less likely but may be woth looking at
If you have SATA drives this is not relevant, but older PATA (IDE drives) can use several methods of handshaking to talk to the IDE controller on the motherboard PIO, DMA, UDMA, found in the BIOS settings in that order, the latter yielding the best performance, if your BIOS dropped back to PIO mode I'd expect to see a massive hit on drive performance
Hopefully this reply may throw some light on the problem
There is another thread http://www.talk.electricianforum.co.uk/showthread.php?t=3451 dealing with hits to system performance but may not be as you have decribed
If you can give me more detail I may be able to narrow this down
PS memory is very cheap at the moment, so you could throw more memory at the problem and see what happens, I'd consider a reformat at this stage as a last resort
