File Transfer
..... unless you were moving very large files of 100MB's+ in size, due the the file buffer design within XP Areas to look
Firstly did this problem start in the last few days?, if yes, have you installed any apps that are taking excessive CPU clock cycles (e.g. at the cost of the File System), every app gets a share of CPU clock time some get more priority than others dependant on this prioritisation, you can check this in Taskmanger, in typical system System Idle Process would be the highest at 99% even with office type apps running (only games tend to tax modern PC's), if you see svchost.exe running at high number this could possibly suggest the presence of a trojan or virus, or you may see a badly written app hogging CPU cycles effecting your file transfers
Where are you transferring from/to? if you have one physical disc split in to multiple partitions you are still using the same read/write heads, small files can be managed by the drive buffers, and larger by the File System buffering (NTFS is more efficient than FAT32), so moving very large files would drag performance down extra memory may not yield much benefit as the bottleneck is the drive, the cure is a second hard drive, the bottleneck moves elsewhere but might not be noticeable
You may have a 100GB of free space reported, but is it contiguous?, Windows is not particularly good at disc space management, so periodically running a defrag app can improve performance on drives as it reorders disc space into contiguous files that will load a lot faster thereafter
OK Robo,
The above quotes from your post are the most relevant..
Defrag is performed on a weekly basis/Window Wash daily.
The files in question are mp3 or FLAC, the latter are converted to mp3 after being decoded.
These files are downloaded (via Torrent) onto the D: partition, if required FLAC/windows audio are converted to mp3 (file sizes 3MB-60MB, up to 1GB in total (or more at times)).
From here they are transferred onto a external HD.
All formats are NTFS.
AVG & Zone Alarms are running all the time.
It does appear that when downloading and performing file conversions that problems occur.
And as you have mentioned, there appears to be a bottle neck occuring.
However yesterday in sheer desperation, I performed a FULL error check (inc auto repair) on the C: Drive..........It appears to have cured the problem (This is the 2nd time I've done this this year).
So is the HD becoming corrupted (occasionally)?
The PC is switched on/off about 32 times a week.
slow file transfers are due mainly to three things: -
1. Not enough resources in particular RAM memory. 1G on XP is not really enough I always recommend at least 1.5G preferable 2G the price of memory now makes this a no brainer really. Just upgrade it!
2. Too much activity on the computer, such as quick launchers, virus checker and background programs.
Use a cleaner tool such as ccleaner to check this out and remove all the unwanted programs that are starting at startup
3. Last but not least dump AVG and get VIPRE from sunbelt. AVG uses too much of the computers resources when it actively monitors for viruses
Good luck
slow file transfers are due mainly to three things: -1. Not enough resources in particular RAM memory. 1G on XP is not really enough I always recommend at least 1.5G preferable 2G the price of memory now makes this a no brainer really. Just upgrade it!
Good luck
Thanks, I'll try a few changes (The RAM upgrade will have to wait for the moment)...
:D
Good luck
1. I'd agree adding memory is cheap and can effect virtual disc performance if you run very large apps Photo Shop etc (not the typical background tasks loaded at start up, if any applet is resource hogging you can throw memory at XP all day long and it will make little if any difference)
Issues that just suddenly appear such as Disc bottlenecks effecting file transfers are caused by; copying v.large files between portions on the same drive, disc sector errors on source disc, and/or loss of contiguous file order, disc management apps are the way to cure these types of issue
2. Agreed in time XP can get cluttered with these applets and will impact overall performance but unlikely just file/disc I/O. XP with 512k suffers constantly with swapping out to virtual disc, many lose patients when opening mail, word, and flood the OS with commands that will bring the system to a crawl "Hourglass" "Not Responding", but background applets tend to be small 3k-5k is typical, as we all agree 1GB is considered the least amount of memory for XP to run reasonably well
3. This very much depends on how old your PC is, a poorly written applet might work well on 3Ghz multi core CPU's, but if the code is not very tight or efficient it bombs on 2-3 year old PC's, you can use apps like Process Explorer (free from Microsoft) to get a more detailed view of how all apps are utilising the cpu clock cycles
I usually have to rebuild my xp machines at least once every 6 months but usually more frequently.
Not surprising. Windows just sux but its a necessary part of life.
Might be worth adding the I/O Reads, Writes and Other colomns on your precesses tab under task manager so you can see if any processes are hitting the drives (would expect the virus scanner to be doing that tbh).
Ian.
I usually have to rebuild my xp machines at least once every 6 months but usually more frequently. Not surprising. Windows just sux but its a necessary part of life.
Ian.
You could also schedule the scanning task to another time of course
As to rebuild I keep a spare drive of the same size to hand for reinstalls, swap over transfer all the hidden files and app data, and keep the old drive to hand for the next time, just in case I miss any files on the rebuild
Another handy tip is to keep the C: partition as free of personal data as possible (some apps will still install stuff on C: :( ) use a second partition for all installs, data etc, this way if you format C: you will still have all your personal files/data on D:
how much catche have u got this is where when u copy something eg: electrical forum it is temperarly stored on the catche sometimes just restarting works but if u have the time and all the software i would reinstall trust me it is the best thing you can do:D
bob
