Twenty odd years ago we had Halon systems where I worked. I recall that had an, "evacuate immediately", alarm system.
Definitely wouldn't be able to breath in that.
Can i give you some advice???? I would not give a **** what ANY supplier said, as all they are interested in is selling you stuff. ASK THE FIRE BRIGADE. or ask the good people of Grenfell..Not a daft question at all, and the answer is no, my first port of call was this forum, but now I've realised the complexities of it, thanks to you, I've contacted a supplier to see what they say about the capacity issue.
That's cool, I'll buy a CO2 extinguisher for now for any possible inverter fires, and try to sort this lithium issue.
Thanks for your advice,
Jay
Best post i have ever read i think!I had a first hand experience of CO2 in operation, not on batteries but on a Rolling Mill in USA that I was involved with programming.
This was a cold rolling process which kerosine is used as a lubricant in a fine mist. The pressure between the rolls is sufficient to cause combustion but the rolls dissipate the heat. That is until a cobble occurs when the sheet material creases / tears etc. Then you have an instant major fire.
The fire can be seen straight ahead and coming out of the left hand part of the mill. The body is my boss legging it. I stayed behind with the mill operator to initiate the fire suppression.View attachment 14432
Thats $50,000 of CO2 being dispensed
You can see being heavier than air it lingers. It was quite a problem for escape, we couldn't leave the pulpit without going through the CO2, we were rescued later with breathing apparatus from the USA Fire Brigade.
Only a PROPER idiot [the same sort of idiot that clads blocks of flats in combustible plastic panels] would have the things in a house..
So you dont have any facts that the batteries are such a major fire risk you'd have to be a 'proper idiot' to instal them inside your property?Early days yet...
If i asked you the day before grenfell how many people have died as a result of plastic cladding i suspect the answer would have been none..
Anything can be 'dangerous' it's a question of risk - how likely is it to happen and if it does the severity of it will be. Usual industrial risk assessment process. Water can kill you.Do some research.. The panels themselves are dangerous too, ask any fire brigade..
john..
As long as you get peace of mind having it there, it's good value, just dont bother trying to put fires out!After what you said yesterday about LifePo4 batteries being safer than standard lithium, I read up on them, and as you say, they are incredibly hard to get to combust, and won't reignite when put out.
I'm just going to get an extinguisher for general electrical fires, just in case my inverters decide to combust. So CO2.
Thanks as always for all the advice, it's as ever, very appreciated.
There was already a lot of concern about cladding from other building fires prior to Grenfell.Early days yet...
john..
Worked in a few places like that, although one I always remember was a fire alarm activation in a server room with a two strike halon system one Saturday morning our on call guy was called to site and the fire brigade were on an automatic call, the on call guy wasn't totally familiar with the site and couldn't locte the activated detector so he called me I was about 2 minutes away so I get to site to find the site porter, the on call guy and the contents of 2 or 3 fire appliances in the server room trying to find what had triggered the alarm, my first question was had anybody disabled the halon gas release as we were only one more detector trip away from the gas as I asked the question I stepped to one side of the doorway to avoid getting trampled as everybody ran for the door, gas disabled it was easy to locate the activated detector as being under the raised floor due to the wall mounted remote detector LED's that no one had noticedTwenty odd years ago we had Halon systems where I worked. I recall that had an, "evacuate immediately", alarm system.
