Flickering LED lights
shawjr83
Dec 10, 2024
7
Derbyshire
Hi all,
We moved into our house about 6 years ago. The house has down lights on the outside wall at the front which are controlled by a timer switch inside the house. In total there are 10 led bulbs.
At the front of the house there is also a junction box which runs from the same circuit and has a further outdoor stake light that goes in a border which had a standard halogen bulb in it.
Whenever the halogen bulb would go this caused the LED lights to flicker when off until replaced.
Recently, we have done our driveway ourselves and added around 12 led lights in sleepers around the border. These all run off the aforementioned junction box outside the house so some on at the same time as the house lights on the timer.
This morning around half the driveway lights were flickering (not the ones on the house) and the halogen bulb had gone again.
I know that LEDS require less voltage to turn on and that there must be some voltage running through the cabling even when off which causes the flicking but I don’t understand why the halogen bulb stops this as all the lights are not in a loop with that at the start - I also understand that halogens require full voltage to turn on.
Ideally I want to get rid of the halogen light but it prevents the above issue and wondering if there is an alternative option?
Is there a dimmer in the circuit? Dimmer to lamp compatibility issues are a common nightmare.
Are they mains led lamps, or are there driver units? Swapping a driver for a different make may help.
It's an awful lot of lamps on one circuit, so splitting it may help.
If not a device known as a snubber, actually a capacitor, wired across the circuit may help.
No dimmer on the circuit.
The LEDs on the house are gu10 bulbs. The ones in the sleeper are an enclosed led unit. All run off the mains.
Try it with just a manual switch instead of the timer for a while see if the problem persists..
I have. Remember, they only flicker when the one halogen gu10 fails that’s on the circuit but not in a loop.
If the halogen fails they flicker when the lights should be off but stop as soon as I replace the halogen bulb with a new one.
Halogens do have a minimum load, leds also do but it’s a lot lower.
The timer may have a minimum load that isn't being met by the LEDs, which having one halogen can meet.
When flickering, is it full brightness ior very dim? The other thing about LEDs is that they can be illuminated just by induced voltages in the cabling, but usually just glow when they do that.
So, looks like a new timer unit for led bulbs is needed
Yep. As said above, if you have a normal light switch hanging around, you could try the lights without any timer, or even just use a bit of connector block to power up the lights without the timer - turn off circuit first of course.
