Fred Clarke
I have a mystifying problem and I am hoping that you might help me to solve it. I have done low-level DIY electrics for the last 50+ years. I hope I can describe things adequately.
I have three 1764mm, 70 watt florescent tubes fitted in my garage. They are on a 2 gang, 2 way switch, one rocker works two lights and the other rocker works the 3rd light.
For three years they have all worked perfectly but a couple of weeks ago, the 2 lights on the one rocker, started coming on in a very haphazard fashion. Maybe one light or the other would come on or maybe not. The next time it was used they would both work ok.
Puzzling enough but a few days ago, neither light would come on. Ah! I thought, they need new starters. New starters fitted. Not working.
OK then, it must be the tubes. New tubes fitted. Still not working.
OK then, it has to be a loose connection in the switch. Checked and every connection is rock solid. I also checked the remote switch at the other end of my garage and again, the connections are good.
I am stumped. Have you any suggestions for me please?
Thanking you in anticipation.
Fred Clarke
Fred Clarke
