small error nicky,,,7 x (58x2) = 812w812w x 1.8 = 1462w
P = IV
I = P/V
1462/240 230 = 6.1A 6.36
Should be ok on a 6B as start up will not be excessive. But are other lamps on the same circuit if so check out the 6A c curve.
But the supposed harmonised voltage to be used is 230vMost places i go have a reading of at least 240, can be 248 for eg.The "actual voltage" is best to make your calculations.
