fuse and mcb numbers
paul copeman
Jul 11, 2011
54
can anyone tell me where i can get a table of all the different en numbers for different types of fuses main switches mcbs rcds etc
i need to be a =ble to identify the numbers but there seem to be so many differnrt types to remember:Blushing
BS 88 Cartridge Fuses (Gen. purpose) - Cartridges fuses for voltages up to 1000v
BS 88-2: 2007 Low voltage fuses
BS 88-2.2:2007 Low Voltage fuses (industrial) for authorized persons
BS88-2.2:1988 Specification for fuses by authorized persons (replaced by BS88-2 (2007)
BS 88-6:1988 Industrial 240/415v (replaced by BS88-2 (2007)
BS 1361:1971 (1986) Cartridge Fuses (Consumer Unit Type) (replaced by BS88-3 (2007)
BS 1363 -1:1995 13a Plugs -2:1995 s/o's, -3:1995 Adaptors, -4:1995 13a FCU's
BS 3036:1958 (1992) Semi Enclosed electric fuses <100a, 240V (rewireable fuses)
BS 3871 Miniature Circuit Breaker (Old Style) superceded and withdraw replaced by BS EN 60898
BS 4293 Specification for residual current-operated circuit-breakers RCD / ELCB / VOLEB superceded by 61008
BS4752 - MCCBs (Superseded by BSEN 60947-2)
BS 5419:1977 Specification for air-break switches, air-break disconnectors, air-break switch disconnectors and fuse-combination units for voltages up to and including 1000 V a.c. and 1200 V d.c. (superceded by BS EN 60947-3:1992)
BS 7288:1990 Specification for socket outlets incorporating residual current devices (S.R.C.D.s)
BS EN 60898-1:2003 Circuit Breakers for a.c. operation
BS EN 60898-2:2001 Circuit Breakers for ac & dc operation
BS EN 60947 Low voltage switchgear and control gear
BS EN 60947-2:2006 Circuit Breakers
BS EN 60947-3:1999 Switches, disconnectors and FCU's (Includes BS 5419:1970 withdrawn)
BS EN 60947-4-1:2001 Contactors & Motors starters
BS EN 60947-5:2004 Control Circuit devices and switching elements
BS EN 61008-1:1995 Main RCDs (not including RCCB's)
BS EN 61009-1 RCB0s
Any errors or ommisions let me know and I shall update as required.
thanks "johninlondon" is this a comprehensive list or are there other numbers for older equipment?
Appendix 1 of IEE Wiring Regulations pages 228 onwards. I'm only in training so don't know them all.
AH,
I have recently come across a 60947-2 for the very first time,
wondered what standard it was related to,
I was going to take a pic and post it up, looks identical to any other MCB.
Steps 60947-2 is the circuit breaker section of the switchgear standard 60947 (with 60947-3 being switch disconnetcors, dont know what the other sections are)
60947-2 *usually* refers to a moulded case circuit breaker, but I think this does not have to be the case, I recently came across some MCBs which complied to both 60898 and 60947-2 (but had a different breaking capacity for each standard!) was a wylex nsb from about 2003 I think!
Rupture (Short Circuit Capacities) in OSG.
Somewhere;
was page 57 in the old one.
^^AH,
it was marked IEC 947-2, not 60947-2
im sure some of our other members will have more information on this
Many of the IEC std references are missing the 60 as a prefix, this is the way it is.
I'd have to check but, IIRC all 2pole & 2 pole mcb's such as Merlin will be 60947, not 60898, or they will be dual marked.
