peter privett
Hi everyone, a bit of advice if you will.
My garage whiich is approx 20 mtrs from the house, is served by armoured cable from house to garage main switch which has RCD & 32 amp mcb serving the sockets and a 5amp for lighting.
All has worked well, until yesterday when a peculiar problem appeared.
Looking at the main switch, the sockets to the right side of this switch are working as they should,
but the sockets to the left, if radio is plugged in, no problem, but plugging in anything heavier trips the main switch in the HOUSE????
what is puzzling me is if there is a fault on this section of wiring,
(A) why doesn't it trip the switch in the garage
(B) why doesn't it trip the mcb marked garage in the house, why the main RCD switch
I have a socket tester and all sockets in thouse and garage are reading OK!
Your help will be really appreciated.
