leatherneck
- Jul 3, 2010
- 12
- 0
This is the picture.
I have had a gas supply fitted for my new self build house and a "Gas safe" fitter has run in the gas supply from the meter into the house.
The gas meter is mounted in a flush fitting box 2m from the front of the house.
The gas pipe (sheathed) fitted today comes out of the meter box and is clipped to the external wall in a trench for approx 12m, there is a "Tee" junction at this point, but this is the first point of entry ointo the house, this is right next to the Electric meter box. The external pipe continues externally for approx 5m were it enters into the house for the kitchen/cooker supply.
Right, the gas fitter said the gas pipe (after the meter) must be earthed within
600mm of the meter. I am convinced it it within 600mm of entry into the house.
If he is correct, then I will need to run an earth cable from the electric meter box 12m back to the gas meter box, surely this is not right?
Cheers,
Leatherneck.
Cheers,
Leatherneck.
