Generators
madzer1988
Oct 16, 2015
2
ireland
I have a 250kva generator supplying a small area with 2 local distribution boards. A 5 core cable goes to the main board and from there there's a 4 core going to one local board and then looped to the other ,with earth bars at both , the earths are neutralised at theses local boards , there was a heavy shower of rain one day and the generator main breaker tripped without the other 2 local boards tripping first , should the generator not be the last to trip I'm confused any explanation wud be appreciated folks thanks
Wud u know of any reason the genny should trip out , a heavy shower of rain shouldn't cause it to trip out
Don't know much about generators, but possibly a fault on the first cable causing the upstream fuse to blow. Or not enough discrimination between upstream and downstream fuses. What fuses were used?
Earth fault protection on the generator doing its job
