boltonsparky
Extractor fans turned off (that's the oldest one in the book).
Family home.
Smoke alarms removed from their bases and nowhere to be seen, leaving the property without smoke detection, the landlord had the radio base interlinked smokes fitted before tenant moved in, the following makes this more of a concern...
Trailing socket cable run from a no access socket behind a very heavy falling apart wardrobe, the wardrobe was sat on the cable crushing it, that same trailing flex led into a 4 way run into the bed, including charger plugged in under the sheets headbang along with another trailing socket running across the room plugged into that with multiple plugs to TVs DVDs sound systems etc. A slight reshuffle of furniture would have made the existing sockets in the room more than adequate.
All the usual rubbish piled up everywhere making it very difficult to get to anything despite the landlord pre-warning them to move anything in the way.
Common sense lacking somewhat.
Family home.
