Hi All,
A Grant vortex 26e combi boiler has been installed and i need to connect a timer unit into it to control the central heating.
I have got two terminals to connect into labelled " timer live " and " timer neutral " for this purpose i believe.
The timer unit has a normally " closed " or normally "open " position choice on wiring. Am i correct in saying the live and neutral to the boiler terminals connect to the normally open position at the timer unit.
The timer unit is a honeywell 111 unit that is being supplied.
With thanks
Rob
With thanks
Rob
