Grant Vortex Oil Combi boiler spares help
Nov 28, 2009
14,762
951
Grant Vortex Combi Oil boiler.
Fault is the boiler fires once radiators warm up, boiler shuts off then radiators go cold.  Go outside to boiler (it is an outdoor model) lights are normal indicating "demand" but no pump and no burner on.
Turn the thermostat knob on the boiler down then back up, boiler fires up again for one cycle then does not come back on unless you repeat with the thermostat knob.
Hot water functions still working normally.
On this one the thermostat knob drives a potentiometer on the one and only circuit board.  My guess it is probably one of the relays not working and I suspect the only cure is a new board.  If only I could find one.
Pictures including numbers:
Any idea where I might get one?
Thanks.  I had tried lots of combination of Grant, Vortex, Board etc on ebay and not found that one.
I await now to see if the customer wants to take that punt.
Too late I'm afraid. E bay just e-mailed that it's sold.  I was hoping it was you.
