Grid systems
lvukol
Sep 14, 2009
20
Any favorite grid systems for anyone or are they all as much of a pain as one another. I only have experience using Legrand and MK.
Will any make of grid system work in a standard 25mm back box or do some only work with there own back boxes?
Many Thanks
i think mk must be the easiest although i havnt worked with loads of them, all i can say is hamilton has to be one of the most expensive much to my suprise! i think i was quoted something like
Every worked with "Varlight PowerGrid"???
Cheapest for what i need from TLC....
I have only used the MK system myself and find them easy enough to work with and they tend to be reliable too :)
any experience with a grid system not fitting in a standard 25mm back box?
do you mean a surface or recessed box? if its surface MK do boxes designed to take the grid.
25mm metal recessed box. Already installed in the wall and now want to install a grid system. Have i got to replace the box with a grid manufactures specific system now?
I only work with the MK range.
One problem I have found is the dimmer range which takes up two slots in the grid (1000watt).
Overheating is another problem and I try to use a deep box if I can.
