I'm about to replace the cable that feeds a small workshop/big shed in my garden.
Currently there is 2.5mm T&E from the CU, thru the house, out thru the wall and off along the ground completely unprotected before going up the wall and entering into the workshop. To top it off, its protected by a 40A MCB.
Proper cowboy job by the previous owner!
I'm going to replace the external run with 10mm SWA, but i dont particularly fancy trying to route that cable thru the tortuous route required to get it from the back of the house to the front where the consumer unit is, so i'm going to joint it onto something a bit more "interior friendly" at the external wall.
The cable isnt buried and doesnt need earthed protection once inside the house, and i'm wondering if i can use H07RN-F?
I was going to use split-con, but no-where local will sell me a section, only selling full rolls as they dont keep it in stock. I could use T&E, but that means running a seperate 10mm earth single alongside which isnt ideal. Its also not ideal for sealing into the external box due to its shape.
Been using a lot of H07RN-F at work for connecting big equipment and realised it might actually do the job just fine.
Cant figure out if its actually allowed or not though?
Any alternative ideas?
