Evening All,
wonder if anybody can clarify the following for me?
I have a hard wired oven on a dedicated 40a supply, connected via a Cooker Switch.
The oven has packed in. I am looking to buy this oven
Belling BI60FP Built In Electric Single Oven. it has the following details
Comes with Plug/Cable No
Electrical Connection 1.905 KW
Fuse Rating13 amps
Power Requirements/Requires Plug/Cable Attaching By An Electrician
So this needs a 13 amp fuse; not sure if it also needs cable.
I just need confirmation that I cannot hard wire this and it must be wired to a plug and then connected to a socket or maybe connect it to a 13amp fuse connection unit?
If my thinking is correct then can i connect the main current cable (from the existing oven ) to a socket or to the 13 amp Fuse connection unit to use with new oven ?
If the new oven needs a cable, is 1.5 m twin & earth sufficient for the plug connection or do i need a thicker cable?
Any information would be most gratefully welcomed!
Thanks in advance!
Fuse Rating13 amps
Thanks in advance!
