Good Evening
I posted a question a while ago and received really helpful advice, something was highlighted separately since then and I wanted to get peoples opinions.
I am moving and will be taking the existing fitting and putting a standard rose fitting back.
It was highlighted that the electrician has the light blue going from the neutral to the live and that this is wrong (certainly sounds it) is that correct?
this particular light can be switched on and off from two separate light switches.
In my new property I plan to repeat how the wiring has been done here but I don't want to repeat an initial error if that is the case.
Currently the light does work exactly how you would expect so if it is wired incorrectly I'm not sure how it works.
