- Jun 21, 2008
- 16,997
- 26
I can do that. Taken from the CU or from the storage heater supply?2.5mm T&E to the FCU.....5A fuse in the FCU.
:^O
Ideally from the CU...I can do that. Taken from the CU or from the storage heater supply? :^O
thanks, but I'm sure there will be further input.thanks for your help chaps, esp ext
The Don's assumes you mean a RCD FCU, if it outside of Zone 2 (17th edition), then there is no issue of concern.Can the FCU be fitted in the bathroom - i assume not because of the test switches ?
