need a little bit of guidance. not sure what the system is classed as but its an oil fired boiler with 4 pipes plus the oil feed, pump external to the boiler, copper cylinder upstairs no valves or plastic header tanks etc. The h/w comes on when you call for the central heating. Question is can some one briefly explain or point me to somewhere i can find out how this system is intended to work. problem seems to be if a lot of hot water is used then the boiler fires and the rads get hot which is creating a problem and draining the oil tank. should there be a 3 port valve or not? could this system be converted to an s plan maybe? any help much appreciated. thanks
