Doodles
Has anyone used a Heger SFT DP changeover switching fitted directly on the DIN rail in the consumer unit rather than using a separate changeover switch enclosure for installing a portable generating set in a fixed (domestic) installation? I am trying to find a solution for limited space in the DB cupboard?
My current thinking is the petrol generator hooking up to an external wall mounted 16A appliance inlet, feeding directly onto the Heger changeover switch before an RCD and several circuits within the CU.
I'm wondering in this unit can serve as both a manual changeover, plus DP isolator (in the central position). If it's suitable rated is there any reason why I can't do this and avoid an extra enclosure??
ta
ta
