Help to identify the main fuse type
phase
Oct 13, 2010
36
Image0311.jpgAnybody can help me to identify the type of this cut off fuse please.
Thanks Phase
NOT VERIFIED
if you cant see it it could be a strip of 1/4" copper for all you know,
and yes, I have seen some that are just that.
even if it has a label or sticker I put NV ,
I could tell you it is a 3036 200amp ,
would you believe me.?
so why would you believe a sticker either.?
Thanks. Is it a fuse on the neutral or it's only the shape. It looks double..
probably fused neutral when installed. may still be fused neutral, or it may have a solid link in now. DNO should be able to tell you. and whats the earthing type?
The earthing is TN-S but the earthing conductor looks undersized... and is connected (bolted) to the body of the CU. Is that ususal practice?
