Hi all
Got a call this morning saying the ring main had gone off in the house. I went expecting a straight forward fault find. I got an IR of .89 on the ring.
When I split it down, one side of the ring (the last 4 skts) is where the problem is, I'm getting a low IR.
The other side is fine up to one particular skt just before the last four. I disconnected the last four (one being an FCU) so that all the legs were left loose. This is where it gets odd
I took the IR from the CU as so.
Phase/E 266Mohms, N/E 235Mohms, Phase/N 436Mohms.
I took the IR from the outgoing cable which goes to the last four skts. I got these readings.
Phase/E 84.7Mohms, N/E >1000Mohms, Phase/N >1000Mohms.
I connected this cable to the socket and retested at the CU and got this.
N/E 196.5Mohms, Phase/N 187.3Mohms, Phase/E 1.628Mohms.
Why would connecting this cable bring the reading down so far?
Sorry for the long winded post, I hope I've explained it well enough.
Malc
Malc
