Frank Salamery
Hi, I have a couple lamps that have different shaped plugs than they would normally have.
Unfortunately this means they don't fit into the plugs on my wall, hence a nightmare trying to turn them on.
Fortunately, as a solution to this problem, I have decided to order some adaptors online.
But this only brings up another problem - I am not sure which ones to buy.
These are images of the plugs in question. As you can see one is normal, and the other is abnormal.
If anyone is able to point me in the right direction in which adaptor I need to/should be purchasing I would be greatly appreciative.
Thank you all.
Thank you all.
