MELODYMAKER81
- Feb 7, 2009
- 5
- 0
Hi all,
I moved into my flat a couple which has an electric boilder and storage heaters. I have previously only used gas central heating so it is all a bit new to me!
Basically there are three heaters in the flat. The first is a small storage heater in the hall way, the second one a panel heater in the bedroom (does not appear to work as a storage) and the third is a large dimplex storage heater in the living room. I can work the bedroom and hall way heater but am having problems with the living room one which I just cannot figure out!
There are two switches located to the left of the heater which seem to be power supplies to the heater. I think one is to use the heater off peak and one peak as and when required.
The switch one the left appears to be the peak one as the heater will work at any time and straight away when I switch this one on but when I switch the other one on and try to use it off peak nothing happens. I know roughly how they work and so understand the heater needs to store heat during the night but despite leaving it on on over night with the input set to 8 or 9 (or indeed any number) it will not store any heat whatsoever like the hall way one. It will as I said earlier work using the other switch any time but of course this is costing me a bomb!
I'm new to storage heaters so I'd be really appreciate any advice or odeas people might have for whats wrong.
Thanks for your help
