Revved Up Sparky
If the cpc is 1.0mm (rather than 1.5mm) then the expected r2 will be 0.18x2.5 = 0.45 ohms which is'nt far off 0.52.
As ProDave said, the socket in question could be faulty. The spring tension can deteriorate over time so that pins of the plugs do not make so good a contact with the socket.
