Hob nuisance trips and makes RCD buzz!
Does this only happen when it is raining/snowing/freezing cold?
The reason I ask is that My Brother-in-law, had an intermittent fault of the main RCD tripping in his house. (when it was raining heavy, etc).
The fault turned out to be a S/O in his garage that was FULL of water. (Mini Trunking and surface mounted S/Os)
Found several other faults too.
:D
It could be something like that Mate.
Does this only happen when it is raining/snowing/freezing cold?The reason I ask is that My Brother-in-law, had an intermittent fault of the main RCD tripping in his house. (when it was raining heavy, etc).
:D
Think it's only happened in clement weather conditions so far....
It is indeed a bit of a mystery, but I will keep you all informed.
