Home study courses
hawkbore
Oct 18, 2008
Hi there everybody, I've been lurking in the background for a while but i have a question now. Has anyone done a home study course for 2391?
I have seen [company name removed] are offering one, has anyone done this or another one.
I was hoping that this might be of use before doing a course and the exam, bearing in mind the low pass rate i have heard about 30% ish!!
Welcome to the forum. I have no-idea about your question tho.
General advice would always be to read as much as you can, familiarise yourself with the material to such a level that you know it in your sleep. There may be a lot to learn but repetition is the key. Think you can save your money and study yourself if you have enough self discipline!
IMO
I am going to do it through my local college.
Welcome to the forum. I have no-idea about your question tho.General advice would always be to read as much as you can, familiarise yourself with the material to such a level that you know it in your sleep. There may be a lot to learn but repetition is the key. Think you can save your money and study yourself if you have enough self discipline!
IMO
That is good advice. I am currently doing a home study course but i'm not just following the course material provided, i'm reading books, manuals, web pages and one of the most useful sources of information - this forum. I just can't get enough information and the one thing I have learned very quickly is that there is a LOT to learn and you can't learn it fast. I've found that by taking it one stage at a time and really, really getting to understand one part thoroughly before moving on. My biggest problem is that because i've been interested in electrics for over 25 years as an amateur that i'm finding that i'm running before I can walk. I have a fair amount of practical knowledge but there's no substitute for learning it properly and thoroughly from the beginning.
Welcome to the forum Hawkbore.
I would think you would be better doing a course at college. I got my quals evening classes. If pass rate is 30% That does not sound very promising.
Batty
college is always better than at home
I'd tend to agree with that one...
You can learn one helluva lot by hearing other peoples questions.....
Someone may look at something from a different angle help you look at the wider picture, and confirm stuff you forgot or missed.
Talking stuff over during breaks with like minded students, is another good source of info and tips..
I remember reading the C&G examiners report on the July 2008 (I think) exam and the reasons given for the low pass rate was because candidates were getting a lot of the terminology wrong and missing out important information.
One question that let a lot of people down, for example, was "What are the four tests made to verify correct operation of an RCD". A lot of students got three but forgot the fourth - press the test button. (Funnily enough, C&G themselves forgot about 180 degree rotation)
Lots of students, also, could not correctly name the the four pages that make up a EIC. Answers included things like "Test results sheet", "Schedule of Tests and Inspections" and suchlike.
Many students failed to correctly differentiate between earthing conductors and bonding conductors and many used terms like Earth Wire.
Another thing that trips up a people is safe isolation procedures (Check that it is safe to isolate (this catches most out), prove the meter, check the voltage, isolate, recheck the voltage, prove the meter again and lock off). In real life, we may not be so precise.
The devil is most definitely in the detail and learning all the correct terminology is fundamental to success. It's one of the few exams where EVERYTHING has to be by the book. When your other half complains that you were muttering about supplementary bonding in your sleep, you are probably well on the way to passing!
Edit: Found a link to an interesting report HERE
Hi
Check out City and guilds 2391 and 2392 courses, Inspection, Test and Certification, C G 2392. I got some stuff from them. It is a starting point but not a complete answer. For the theory part of the exam you need to know IEE Guidance Note 3 pretty much off by heart.
If you are not a practising electrician I can't see how you can prepare for the practical from home. The practical exam is a pressure test of testing and filling out forms.
When I took the exam only about five out of around forty delegates passed. According to my lecturer most fail because they cannot put their thoughts succinctly on to paper in the theory exam rather than a lack of skills in the practical.
You can get past papers and plough through them. At least you get you mind set in the right sort of focus.
