I have a 3 kw Honeywell fan heater with a moulded plug. After running for about 15 mins the plug gets hot as does the cable emerging out of it. Measuring with an IR thermometer it reads 40 C on the plug back and 60 C on the cable outlet. Many years ago I had a similar problem with a conventionally wired plug on a fan heater and that was down to a loose connection on the neutral caused by the ends of the wire having been solder dipped and worked loose by heat and screw pressure no doubt, something which I no longer think is done.
Would it be sensible to rewire the plug or could there be another reason for the plug getting hot e.g poor quality socket?
