Hi All!as im sure most of you are aware by now i dont do alot of my own work, i mainly subcontract for larger contractors, However, im tring to do more of my own work.
anyway, ive been asked to quote for this job and wondered what you would all charge for labour.
Install Mains Powered Door Bell
replace light fitting in downstairs hall
replace light fitting in upstairs hall
Install 4 x GU10 Spot Lights in bedroom #1 (Fire Rated)I assume there is a loft above so why fire rated
Install 4 x GU10 Spot Lights in bedroom #2 (Fire Rated)I assume there is a loft above so why fire rated
Remove Light In Bedroom #1
Remove Light In Bedroom #2
Remove Light & Pull Cord in Bedroom #2
Install Remote Control Light Switch in Bedroom #1
Install Remote Control Light Switch in Bedroom #2
Replace 6 x LV Spot Lights in BathroomIP65 required,, got to stop humid air getting into loft space
Remove Light fitting in kitchen
Install 2 light fittings in KitchenIf difficult access you're going to have to cut holes as said earlier
Chase Ceiling In Kitchen
Replace 22 Double sockets with flush fit Chrome& replace knock out boxes with 35mm
Replace 1 x 3G Dimmer with flush fit chrome& replace knock out boxes with 35mm
Replace 6 x 1G Switch with flush fit chrome& replace knock out boxes with 35mm
Replace 1 x 3G Switch (2 x 1way 1 x 2way) with flush fit chrome
Replace 1 x TV Ant Socket with flush fit chrome& replace knock out boxes with 35mm
Replace External Light fitting
Test & Inspect all work carried out & issue certificate
The ceiling in the kitchen is in accesable so the only way i can think of wiring is to chase the ceiling, is this how you would all do it?
any help on this would be very useful! i told the client i would send the quote in the next day or so.
